8.0.3 -
A single selection variable dropdown that I can access different values for. -
In the my_var variable setup:select id as __value, name as __text, bar_id from my_table
In the panel query: SELECT * FROM foo WHERE id = $my_var AND bar = $my_var$bar_id
- What happened?
$my_var works for returning the__valuebut I cannot figure out how to access the other columns of the variable.
Is what I am doing possible? I am using postgresql, but struggling with how I can use the variables, so any general pointers is helpful as well!
