Can't gey chart displaying data when selecting more than one value in dropdown in flux query
Hi, the below query works fine until I select more than one item from the variable q_line
from(bucket: "volt_sense")
  |> filter(fn: (r) => r["_measurement"] == "mqtt_consumer")
  |> filter(fn: (r) => r["location"] == "rd2")
  |> filter(fn: (r) => r["_field"] == "${q_line}")
  |> aggregateWindow(every: v.windowPeriod, fn: mean, createEmpty: false)
  |> yield(name: "mean")
when I inspect the query I get the following output
  |> range(start: 2023-07-12T01:26:52.391Z, stop: 2023-07-12T01:56:52.391Z)
  |> filter(fn: (r) => r["_field"] == "{A0,A1}")
  |> aggregateWindow(every: 1s, fn: mean, createEmpty: false)
  |> yield(name: "mean")
however, I think the line should look like this
|> filter(fn: (r) => r["_field"] == "A0" or r["_field"] == "A1" or r["_field"] == "A2" or r["_field"] == "A3")
how can I get a result like this in a multi-select variable?
Any help would be greatly appreciated?
I also get the same as you do above. I will try to find a solution.
I see a possible solution on the InfluxDB forum:
But on my test system, I get an error (I am selecting 203, 204 and 206 in my variable):
invalid: compilation failed: error @4:44-4:66: regex parse error: {203,204,206}:regex} error: repetition operator missing expression
Works for me! Thanks @yosiasz
Multi-value variable called TemperFurnaceNumber in Grafana and regex query in Flux:
  |> filter(fn: (r) => r["EquipNumber"] =~ /^${TemperFurnaceNumber:regex}$/ )
Inspect >> Query:
