Is there any update for Statistics/Data Gauge Panel where we can set a variable as thresholds?
I’m currently using Grafana 8.0
I already found a way to set variable threshold for panel.
In my case I need changeable Monthly Cumulative result for yield for each product selected that must be located in one page only
I used Status Panel instead.
Then set the the Actual Yield formula and Monthly Target Yield as variable
and used Case-when formula.
Glad it worked well.
