v9.3.0 in Ubuntu 18.04.4 -
I am trying to provide data links based on values in a state timeline. -
I have two queries to a PostgreSQL database. The data links are created using overrides for each query with values given by ${__value.text} or ${__data.fields[1]} (either variable gives identical behavior). -
What happened?
Variable values are incorrectly given as though the two tables from the queries have been flattened into a single table. The first values shown in the image below (e.g. 031615) have correct variable values, while later values have incorrect values, such as ‘031648’ having a data link value of ‘031627’.
I expected the variable to have the same value as is shown in the stat panel. In the image above, that would mean the panel and variable both have the value ‘031648’. I’ve previously created this panel using an influxDB datasource and seen the expected behavior. The panel also behaves as expected if either query is disabled. -
See above. -
No. -
PostgreSQL data source | Grafana documentation
Configure data links | Grafana documentation
State timeline | Grafana documentation
