This def sounds like it could be a bug. If you haven’t already, could you make an issue in the Grafana repo?
Hi, I have the same problem, is there a task for this? I can not find it. Use Graphana 9.2.2 (now upgraded)
It happens with Barcharts as well as with Time Series Panels, maybe others are also affected.
I just added my screenshot from the Time Series Panels to the Github issue.
As workaround you can just hide it by changing a couple other parameters to make it invisible:
Good afternoon, still this issue exist. Is there any update in the meantime? The solution of @michaeluray is not suiteble for me since it will totally change the layout of my axis.
thanks for the workaround idea @michaeluray !
I would love if this where fixed so it doesn’t need a workaround though
Also: the workaround will still allow the mouse to snap to the invisible line, which is confusing since the user can’t see it ^^
