I got this panel (stat) made and I am duplicating it to use it again for another column in my database (I am changing the query also). I am also transforming this value to a integer. For some reason all stat panels I have copied, get the value set to a random one from another one of the stats:
“Active Time (not found)” pops up in the transfromation and all my stats have “no data”. Does this have to do with the fact that I duplicated the stats?
What is the problem here? How can i fix this?
