Hey,
is it possible to output an UTF-8 symbol in the replace field of the Rename by regex function under the Transform tab?
I would like to use one of the telephone symbols mentioned here:
Regards
SchiSchi
Hey,
Regards
SchiSchi
Welcome
What is the datasource you are getting data from and what in the data source do you want to replace with these icons?
using icons from 🙈 See-No-Evil Monkey Emoji
My datasource is an InfluxDB.
I managed it by myself.
I simply copied the symbol from W3C website and pasted it into the textfield in Grafana. Works ![]()
