Using regex OR as a value for a custom variable
I’m trying to create a custom variable that has values that contains some regex expression (e.g. ua|uat, int|prer) that will be used as the regex filter in another variable
example:
Let’s say I have a variable like
  • Name : _type
  • “Values seperated by comma” : uat|ua, int|prer
and another variable like
  • Name : _env
  • Query : (returns a list of environments)
  • Regex : /$_type$/
the regex, does not seem to filter the query results properly when “uat|ua” is selected. However, if I replace $_type with /uat|ua/ in the Regex textbox, it works.
Note: I’m trying to filter the queried list for values that end in UAT or UA, etc…
Any ideas?
Thanks
have you found a work around for your issue?
Hi, I have the same problem. Did anybody found a solution?
The regex should look like:
/(${_type:raw})$/
The brackets could be inside the the custom variable value as well, “All” value probably should be .*
An alternative is to use a variable with multiple selection, e.g
$_type custom values:
Var1 : uat, Var2 : ua, Var3 : int, Var4 : prer
Query:
/$_type$/
Select Var1 and Var2 and the query would be resolved to:
/{uat,ua}$/
For one-letter multiple variants one could use:
Var1 : at, Var2 : rq
Query:
/[$_type]$/
which would match “rat” and “plant” with Var1 selected, but that wouldn’t work for the original problem without renaming things in data.
