Use custom variable in regex of transformation 'Filter data by values'
    Grafana 11.1.4
    Use custom variable in regex of transformation ‘Filter data by values’ to filter single values and also show all values.
  • What happened?
    I get ‘No data’
    Return data based on regex
The variable $MyColors has custom values like this:
  • red
  • green
  • blue
I entered the value .* in ‘Custom all value’. This is to show records with any color as ‘All’ option.
But for some reason I always get ‘No data’ no matter which color I select.
If I enter .* manually inside the transformations value field, the data is there as expected.
It works also if I enter one of the colors inside the transformations value field.
It seems that the custom variable is not considered or evaluated by the regex?
What I am missing please?
Please note:
I know that I can use custom variables in the database query, but I want to achive a client side filtering to avoid multiple queries against the database if user changes the color value.
transformationsVariableSupport is already enabled (by Grafana default)
@mrburns
Try → ${MyColors:regex} instead of $MyColors
@orosolido: Thanks, but this does not change anything :frowning_face:
@mrburns
hmm :confused:
Just as a test… try to see if the variable works. For .e.g.
put it in the title options and chance values.
ps. what Datasource are you using?
@orosolido: good idea,
Here the results for the title:
.* instead of All
red instead of red
green instead of green
blue instead of blue
I use mysql database, but this should not make any difference what database I use.
@mrburns
Agree, it shouldn’t matter
I was more aiming for the idea to integrate it into your query instead of using the transform feature.
It looks like it works. The question which now is .do $variables also work in combination with TRANSFORM.?
Let me check
I know that I can use variables in query. But this is what I wanted to avoid as I posted in my 1st message under the ‘Please note’ section.
I don’t want to run another query against the database server. I want to get client side filtering to speed up and reduce load on database server.
@orosolido: Thanks for your help, but:
I now downloaded Grafana 11.2.0. and there it works :grinning:
I also can use just:
$MyColors
Inside the Value of the regex field:
@mrburns sure np!
Good to hear. I was about to msg you that for it didn’t work :sweat_smile:
So this is an issue in older versions
Yes - thanks!
i am trying to add the condition in the transform “Filter by value” but add condition button is not working, i tried in different browsers… please advise
Step 1: Open the grafana.ini file
C:\Program Files\GrafanaLabs\grafana\conf\grafana.ini
Step 2: Find the [feature_toggles] section and add this feature.
[feature_toggles]
transformationsVariableSupport = true
Step 3: Now apply transformation it will work.
