Using query variable
Hello, I am very new to Grafana.
I would like to build boom table with query like
sum(sellercenter_income_total) by (seller))
But this gives me lots of data and I can’t save a dashboard.
For this reason I tried to limit the data
topk(20, sort_desc(sum(sellercenter_income_total) by (seller)))
but it sorts data incorrectly.
I found that I can create query variable in order to get correct sorting.
I created a query variable with query
query_result(topk(20, sort_desc(sum(sellercenter_income_total) by (seller))))
The problem is that I don’t know how to use this variable in boom table.
Using just $variable_name doesn’t work for me.
Can you please help me to figure it out?
Thank you.
