Using Grafana with SSL on Debian LAMP server
I run Grafana on a Debian server that is primarily used for our groupware solution.
On this server I have SSL set up for Apache - with LetsEncrypt. This works fine - and LetsEncrypt is automatically updated with a cron job etc.
  1. Can I use the same LetsEncrypt setup for accessing Grafana via SSL on this server?
  2. On the same server I can not use Grafana at all with http: on Firefox - but Chrome & IE works :
Example:
http://mysite.com:3000 works fine in Chrome and IE.
If i try with Firefox, the site is automatically redirected to https://mysite.com:3000 and Firefox says “SSL_ERROR_RX_RECORD_TOO_LONG”
Thanks for all help!
