Using Grafana Test Data Datasource plugin for learning and testing scenarios
Dear Community members :wave: ,
I have created this in-detailed guide on how to use the Grafana default Test Data (aka TestDB) Data source plugin to get started with Grafana :grafana: .
It will help to create various visualizations and understand different test seniors by modifying its pre-configured data.
Also, you do not have to do any configuration as this Data source is part of the core plugin and is available in all Grafana versions (open-source, enterprise, cloud) :slight_smile: .
Link to video
Link to Blog
https://medium.com/@syed_usman_ahmed/using-the-test-data-data-source-in-grafana-for-testing-and-learning-967fc3f3184b
I hope this helps :slight_smile:
