I just installed Grafana and I’m trying to go through the getting started steps. One step is to enable the testdata at http://grafana.staged-by-discourse.com/plugins/testdata/edit. The instructions are not clear ( Grafana TestData is not enabled by default. To enable it, first navigate to the Plugins section, found in your Grafana main menu. Click the Apps tabs in the Plugins section and select the Grafana TestData App.) as there is no Apps tab on my Plugins page. There is a list of plugins, and one is called TestData DB (rather than TestData App). It follows the url stated later in the instructions “(Or navigate to http://your_grafana_instance/plugins/testdata/edit to go directly there). Finally click the enable button to enable.” However, when I go to that url I don’t see an Enable button, just an empty Readme (almost empty, actually, as it does say “Dependencies Grafana *”
It seems as if my version of the docs don’t match the product. Is there a newer version of the docs?
