Using environment variables to disable Angular plugin warning in Grafana11
    Grafana OSS v11.0 on Docker
    Disable the deprecation warning for Angular panel plugin using environment variables. I would like to not use a config file if possible because I have done all the other configuration via environment variables It is not very well documented how to use environment variables to disable feature toggles, only enable new ones, at Configure Grafana | Grafana documentation
    I have used this environment variable: GF_FEATURE_TOGGLES_ANGULARDEPRECATIONUI=False
  • What happened?
    The deprecation warning is still shown when I open a dashboard with an Angular panel plugin.
    No deprecation warning should be visible
    No
    All other Grafana environment variables have been set using the official documentation (and works), but the documentation for feature toggles and environment variables is not clear: Configure Grafana | Grafana documentation
A similar question for another feature toggle has been asked here, but no replies: How to disable feature toggle that is enabled by default
Can’t believe there is still no solution for this. What an absolute garbage. You put an annoying warning over every single dashboard and there is NO WAY to remove it when using Docker. Stupid decision.
