Is there a way to use an alias, ie - {{ metric }} or {{ stat }} as a panel title variable?
What i’m trying to accomplish is:
Using AWS CloudWatch Datasource with Grafana 6.3 Beta and repeating rows with DocumentDB Clusters.
cluster variable = api-production
metrics = CPUUtilization, Connections, and so on
I’d like the per panel titles to look like (using repeating rows)
$cluster.{{ metric }}:
api-production.CPUUtilization
api-production.Connections
Is this possible? If I try to use {{ metric }} in the panel title it just treats it as a literal and does not expand the same way as a variable
Thanks!
