9.5.13 – Yes, I know that 10 is out, but I have a hunch that won’t change much. ![]()
- What are you trying to achieve?
When using an ES datasource for Percentiles, “Values” is pre-populated with what appears to be a comma-separated list. I want to use one or several values from a variable.
- How are you trying to achieve it?
I put that sort of comma-separated list into a variable and reference it in this field.
- What happened?
The query fails and can not be inspected through the query inspector. Several variable formatting options didn’t help.
Achieve the same as if I had entered the percentiles in the form myself.
I know that this doesn’t go done to the bottom. I was wondering whether this is a bug or if I’m stupid. I would argue that “wrong” input should lead to a situation that can still be debugged easily. When I looked at the original working query, I think I saw that it is converted into [“25”, “50”, …] for the request. This sort of magic apparently is not something I can circumvent.
