User created by logging in with Google OAuth is not administrator
    Using Grafana in Google Kubernetes Engine via prometheus-stack
    Grafana image is docker.io/grafana/grafana:10.3.1
    Configure Google Authentication so that when a specific user logs in and has their account created, they are an administrator.
    Following the document mentioned below (can only include 2 links), we have ended up with /etc/grafana/grafana.ini that I’ve pasted in the configuration block below. The specific lines relevant to this are
allow_assign_grafana_admin = true
role_attribute_path = email=='me@mydomain.com' && 'Admin' || 'Editor'
I’ve also tried with GrafanaAdmin instead of Admin in the above role_attribute_path
  • What happened?
    The user is logged in and created, but does not have administration privileges. If I login as an admin user, I see that Grafana Admin is set to No in the UI.
    I expected the user to be logged in and an account created as an administrator account.
reporting_enabled = false
[analytics]
check_for_updates = true
[auth.google]
allow_sign_up = true
allowed_domains = mydomain.com
allowed_groups = our.team@mydomain.com
auth_url = https://accounts.google.com/o/oauth2/auth
client_id = ${GOOGLE_OAUTH_CLIENT_ID}
client_secret = ${GOOGLE_OAUTH_CLIENT_SECRET}
enabled = true
scopes = https://www.googleapis.com/auth/userinfo.profile https://www.googleapis.com/auth/userinfo.email, https://www.googleapis.com/auth/cloud-identity.groups.readonly
token_url = https://accounts.google.com/o/oauth2/token
[dashboards]
min_refresh_interval = 60s
[grafana_net]
url = https://grafana.net
[log]
mode = console
[paths]
data = /var/lib/grafana/
logs = /var/log/grafana
plugins = /var/lib/grafana/plugins
provisioning = /etc/grafana/provisioning
[security]
disable_gravatar = true
[server]
domain = ''
enable_gzip = true
root_url = https://grafana.mydomain.com
When logging in to create the account, the logs show the following:
logger=context userId=0 orgId=0 uname= t=2024-02-06T16:28:33.058758785Z level=info msg="Request Completed" method=GET path=/login/google status=302 remote_addr=147.12.244.38 time_ms=0 duration=899.93µs size=647 referer=https://grafana.mydomain.com/login handler=/login/:name
logger=context userId=0 orgId=0 uname= t=2024-02-06T16:28:39.997115469Z level=info msg="Request Completed" method=GET path=/login/google status=302 remote_addr=147.12.244.38 time_ms=653 duration=653.364239ms size=24 referer=https://accounts.google.com/ handler=/login/:name
logger=context userId=7 orgId=1 uname=me@mydomain.com t=2024-02-06T16:28:40.242985891Z level=info msg="Request Completed" method=GET path=/api/live/ws status=-1 remote_addr=147.12.244.38 time_ms=1 duration=1.566925ms size=0 referer= handler=/api/live/ws
In the UI, the user has the expected e-mail address that is used in the role mapping.
Switching from an e-mail to a group solved this for us.
role_attribute_path: contains(groups[*], 'grafana.admins@mydomain.com') && 'Admin' || 'Viewer'
