v8.3.1
Windows -
I’d like to use the State timeline to visualise when some series are active. The trick is that the data looks slightly different from what seems to be the expected format.
Instead of
|<timestamp>|<metric_name>|<metric_value>|
It is formatted as
|<metric_name>|<timestamp_start>|<timestamp_end>|
The metrics only have 2 values, active or inactive, so each row corresponds to one activation and ensuing deactivation. -
I’ve tried to unpivot the data but this doesn’t populate the <metric_value> column, which is still expected by the visualisation. I could try to somehow build the query so that it generates a 0,1,0,1,… sequence for this column but I wonder if this is the best way to go about this. -
What happened?
The furthest I got was to add a
,1 as value
so that the visualisation is at least generated, but it’s clear that (as expected) it’s not looking as desired. -
Ideally I’d expect this visualisation to, when provided with data that has 2 timestamp columns and no value columns, imply that these correspond to start and end times and plot accordingly. -
No -
I couldn’t find any but happy to follow if there are.
What is your data source?
I was unable to use this visualisation with Postgres as a datasource, because it only works with time-series formatted data. But any relational database would give you data with one row per label instead, so you have to pivot the data – which is OK if the set of labels is known in advanced, and otherwise essentially impossible.
I also tried using the transformation " Prepare time series", but that only works if the values are numerics, which they aren’t in this case.
Same challenge trying to use the Bar Chart plugin with a relational database.
The data is pivoted, I suppose the solution involves unpivotting, which is what I had attempted to do
