Cloud
- What are you trying to achieve?
I used the following data transformation on the query result
The resulting table has a row for each timestamp with a column for each grafana instance. The value of each cell is used to define the state of the grafana instance.
I want to create a state timeline from this data
- How are you trying to achieve it?
Creating a state timeline visualization
- What happened?
I get an error “Data does not have a time field”
The data be displayed as a state timeline for each instance (column)
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
- Did you follow any online instructions? If so, what is the URL?
