v8.5.20
I have a variable called ownerID which has 2 possible values
3 - Value 1 -
8 - Value 2I want to use only the 3 or 8 as input to an SQL query in another variable.
In other words, if the user selects 3 - Value 1, the SQL query in the second variable would only use the 3
Example:
SELECT name
FROM tablex
where Id=“This is what I need - it should use the value 3”
I have tried regex but can’t get that to work -
I expect the SQL query to return the value name associated with Id = 3
