Hi all, I want to use a trend graph panel from grafana in an own webserver like nodejs.
The solution should only be the panel without some configuration stuff. For example just the div element where the graph is shown.
Can anyone help?
或许有一个配置可以试一下,将?kiosk参数添加到网址。
Thanks for your reply.
Is there any option to stay in the kiosk mode? Because if you press d+k on your keyboard you will toggle between kiosk mode and normal mode.
