I want to create a frontend app that contains the Grafana graphic panel and tables.How can i use it?Do i need to dive into the Grafana codes and modify it?
Yes, you can modify it. It’s not easy to embed in another web application (unless you iframe)
http://docs.grafana.org/project/building_from_source/#building-grafana-from-source
Every panel’s share function have a embed that contains a iframe html code. Does it you want to talk to me ? I know this way can embed in my web application yesterday, thanks very much.[quote=“torkel, post:2, topic:2235, full:true”]
you can use auth proxy feature, put grafana behind nginx / reverse proxy and send the user via http header
[/quote]
How to defined the nginx / reverse proxy server ip address in grafana config file?
what? you mean a white list for the auth proxy? yes there is a such an ini option.
