Use of SQL datasource in Apache eChart
Hi there, Im trying to use the Apache Echarts with my sql Query in Grafana but unable to sort what is wrong with my code. The current error im getting is = Echarts Execution Error Data is not defined.
Grafana v- 9.5
Apache echarts - 5.X
Table View comes correctly
with school name and ticket count per school
eg:
TableView:
School a - 10 tickets
School b - 11 tickets
School c - 12 tickets…
SQLQuery named as A
SELECT top 5
company_name as ‘school’,
count([dbo].[v_rpt_Service].[TicketNbr]) AS ‘ticket’
FROM v_rpt_Service
WHERE Board_Name IN(‘Field Technicians’)
–AND Parent is null
AND closed_flag = ‘0’
AND SubTypeItem_RecID !=305 --Maintenance Visit
Group by company_name
My code :
let school = ;
let ticket = ;
data.series.map((s) => {
if (s.refId === “A”) {
school = s.fields.find((f) => f.name === “school”).values;
ticket = s.fields.find((f) => f.name === “ticket”).values;
return {
grid: {
bottom: “3%”,
containLabel: true,
left: “3%”,
right: “4%”,
top: “4%”
series: [
data: school,
itemStyle: {
borderColor: “#EE6666”,
borderWidth: 3,
color: “yellow”
lineStyle: {
color: “#5470C6”,
type: “dashed”,
width: 4
symbol: “triangle”,
symbolSize: 20,
type: “line”
xAxis: {
data: ticket,
type: “category”
yAxis: {
type: “value”
My Json from query(Grafana) is this:
“schema”: {
“refId”: “A”,
“meta”: {
“executedQueryString”: “SELECT top 5\r\ncompany_name as ‘school’,\r\ncount([dbo].[v_rpt_Service].[TicketNbr]) AS ‘ticket’\r\n\r\n\r\n–CASE WHEN Ticket_Owner_First_name is null THEN ‘Unassigned’ ELSE CONCAT(Ticket_Owner_First_Name, ’ ', SUBSTRING(Ticket_Owner_Last_Name, 1, 1)) END AS Owner, [dbo].[v_rpt_Service_Open].[company_name] AS ‘Company_name’, [dbo].[v_rpt_Service_Open].[status_description] AS ‘Status Description’, [dbo].[v_rpt_Service_Open].[Age] AS ‘Age’\r\nFROM [dbo].[v_rpt_Service] WITH(NOLOCK) \r\nWHERE Board_Name IN(‘Field Technicians’) \r\n–AND Parent is null\r\nAND closed_flag = ‘0’\r\nAND SubTypeItem_RecID !=305 --Maintenance Visit \r\n\r\n\r\n\r\nGroup by company_name\r\n”
“fields”: [
“name”: “school”,
“type”: “string”,
“typeInfo”: {
“frame”: “string”,
“nullable”: true
“config”: {}
“name”: “ticket”,
“type”: “number”,
“typeInfo”: {
“frame”: “int64”,
“nullable”: true
“config”: {}
“data”: {
“values”: [
“ABC school”,
“Point A school”,
“Bob’s school”,
“Jusep School”,
“Don Lord school”
7,
12,
7,
9,
13
Echart:
https://echarts.volkovlabs.io/d/tg6gWiKVk/line?orgId=1&editPanel=28
Any help appreciated.
this article didn’t help , was using as reference.
Do I need to set this or just in the code?
The ‘data’ variable they are using can be found (at least I found it) in context.panel.data. So:
let data = context.panel.data;
Tip: In chrome ctrl + shift + J will open the console. Then you can use console.log(stuff) to see what stuff is.
