Grafana 7.1.1 on Windows 10 -
“Dashboad Save As” without entering the settings page -
Use a dashboard link -
What happened?
nothing so far -
nothing so far -
n/a -
n/a -
n/a
Is it possible to Save As the current dashboard using a dashboard link ? If so, how should the link etc be entered (provided that localhost:3000 is the server) ?
We do have a spicific use case where a viewer should be able to save the provisioned dashboard in some folder with the current settings. The viewer does have the settings button but no save as button. Furthermore we (engineers) need to setup grafana for users that are not engineers. So simple “save as” functionality is required.
