UPTIME convert from seconds to day on Grafana?
I am configuring a metric, for Uptime of a device. Our Grafana is integrated with Zabbix. I am collecting the key data “sysUpTime.0” which are second. Can I convert Grafana from seconds to day?
Try unit format duration Seconds
Hello Torkel, thanks for the feedback.
When I do the snmpwalk command on the SysUptime key, it is returning the value in seconds (79669500) and in days (9 days). See command below:
snmpwalk -v 3 -a MD5 -A xxxx -X xxxx -u cis -l authpriv 10.65.126.202 sysUpTime.0
DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (79669500) 9 days, 5:18:15.00
In zabbix, there is a Multiplier field, where I multiply the seconds by 0.01 and arrive in the 9 days. In Grafana, I can not do this, the value appears in the second without the multiplier. I would like it to appear the 9 days, according to SNMPWALK command
Did you try the unit duration? It will automatically format seconds to days, you specify unit in the options tab
Yes, I did,
I’m sending pictures of Grafana and Zabbix ( Zabbis is OK )
you screenshot does not show options tab, and it does not show you have selected the right Grafana unit in the Options tab of the singlestat panel!
Hi brambila
you can try change the Options-Unit-seconds(s) and set the Decimals 0
form a chinese engineer :slight_smile:
Hello! Any way to convert seconds into days in the Table not in the Singlestat?
hi works perfect, look at the photo
I encountered the same problem, Up time shows as Seconds by default, so I just included in the SELECT section of the Query editor the “math( /86400)” and the result shows the value in Days, you can put decimals to be more precise.
Note: I am using Grafana with Influx Db and Telegraf Plugin.
hope this helps :slight_smile:
