Grafana Single Stat - Timeticks (Uptime)
Hi guys,
I’m having issues with timeticks (basically System Up Time) from one of the SNMP enabled devices.
I’ve selected “Options” → “Time” → “duration(s)” but the data is showing as 23 years!
The actual data is 85 days as shown below from the snmpget output
Timeticks: (737365657) 85 days, 8:14:16.57
Screenshot also attached, am I missing something? Any help appreciated - thanks!
It expects a time value in epoch, i.e. number of seconds elapsed since January 1th 1970. Checking your time value at https://www.epochconverter.com/ shows Friday, May 14, 1993 7:47:37 AM GMT, i.e. ~23 years ago.
Seems like your time ticks value is in some other format than epoch.
Marcus
Thank you @Marcus, makes perfect sense.
Did this to get to # of days:
timeticks / 8640000 = days
