Hi all. We have an old installation of Grafana 10 that I need to upgrade to version 12 (I’ll wait for 13.1 to upgrade to 13
). Do you all recommend upgrading to 11 first, then from 11 to 12?
Thanks!
Thanks!
Welcome @dandelaney
Upgrade 1 version at a time is best.
As always make a backup of pertinent ini and db before upgrading
Thanks @yosiasz. Should it work to go straight from 10.4 to 11.6 to 12.4, or would it be best to go to 11.0 first, then 11.6, then 12.0, then 12.4?
The first approach should be fine.
Excellent. Thank! I appreciate it.
