Previously on older (v7) versions of Grafana I could put images into the Grafana public directory and display them on my dashboards. This worked for images in the public directory AND for images behind a symbolic link/symlink in the public directory.
Is there a config change I can make to allow symbolic links again? Or an alternative solution?
But now in v9.0.1 it seems something has changed and images behind symlink/symbolic link cannot be shown - Grafana gives a 404 error.
Grafana v9.0.1 installed (.deb) on Ubuntu -
Show images on my Grafana dashboards. -
Case 1: Copy an image here:
/usr/share/grafana/public/my_pics/my_image.jpg
and reference it using URL:
https://my_grafana:3000/public/my_pics/my_image.jpg
Case 2: Copy an image here:
/usr/share/grafana/public/my_symbolic_link_to_pics/my_image.jpg
https://my_grafana:3000/public/my_symbolic_link_to_pics/my_image.jpg
- What happened?
On older (v7) Grafana both case 1 and case 2 worked fine.
On v9.0.1 Grafana only case 1 works. Case 2 now gives 404 error.
