version 12.4.1, with official docker image deployed in K8s -
upgrade from 12.4.1 to 13.1.1 -
Update the image tag in deployment configuration in K8s. -
What happened?
DB error shown as below:
Error: ✗ migration failed (id = Increase precision of team.updated to DATETIME(3)): pq: duplicate key value violates unique constraint “migration_log_pkey” (23505)I have checked our postgresql db of the migration_log table, but can’t find this item.
id = Increase precision of team.updated to DATETIME(3) -
Thanks, @kimberlyyerhot63 .
I will try very new version till this issue fixed.
One possibility is that the sequence backing migration_log.id is out of sync with the table, since that can result in duplicate primary key errors. However, the error alone doesn’t confirm that’s the cause.
Could you also share →
the full Grafana startup log from Starting DB migrations through the duplicate key value violates unique constraint "migration_log_pkey" error, and
whether only one Grafana instance/pod was running while the upgrade was performing the database migration?
That should help determine whether this is a sequence issue, concurrent migration attempts, or another migration problem.
Thanks, @infofcc3 .
You give me an idea to rollback grafana db to an older version and seems works.
Please close the ticket.
