Upgrade from v8 to v10: Alerting
I just tested the upgrade of our Grafana from v8 to v10.
To upgrade alerting, I’ve read that I can use “Upgrade with Preview” under “Alerts & IRM”.
I had enabled the feature “alertingPreviewUpgrade”. But after I started the v10.4.8, I could not find this View. :frowning:
Do you have any idea, what I could activate this Preview?
Thank you very much for the help!
Chuan
found the solution self :slight_smile:
FYI, at first, we must deactivate the new [unique-alerting] and activate the old one: [alerting]. Then the tool/review will be shown.
Regards,
Chuan
