Upgrade from grafana Version 11.2.2 to version 12.0.2
Dear Team
We are trying to upgrade Grafana v11.2.2 to version 12.0.2.
The version v12.0.2 is running correctly, but when we replay the grafana.ini and grafana.db we see the follow error.
"oot@localhost:/etc/grafana# systemctl restart grafana-server
Warning: The unit file, source configuration file or drop-ins of grafana-server.service changed on disk. Run ‘systemctl daemon-reload’ to reload units.
root@localhost:/etc/grafana# systemctl status grafana-server
Warning: The unit file, source configuration file or drop-ins of grafana-server>
× grafana-server.service - Grafana instance
Loaded: loaded (/usr/lib/systemd/system/grafana-server.service; enabled; p>
Active: failed (Result: exit-code) since Mon 2025-07-07 15:05:23 -03; 6s a>
Duration: 466ms
Docs: http://docs.grafana.org
Process: 46981 ExecStart=/usr/share/grafana/bin/grafana server --config=${C>
Main PID: 46981 (code=exited, status=1/FAILURE)
CPU: 504ms
Jul 07 15:05:23 localhost.localdomain systemd[1]: grafana-server.service: Sched>
Jul 07 15:05:23 localhost.localdomain systemd[1]: grafana-server.service: Start>
Jul 07 15:05:23 localhost.localdomain systemd[1]: grafana-server.service: Faile>
Jul 07 15:05:23 localhost.localdomain systemd[1]: Failed to start grafana-serve>
Any tips to help us?
Regards
Jorge PLautz
Hello team.
We found a solution.
We installed grafana enterprise version and it works correctly.
Regards
Plautz
