Update flashes - distracting
Hi.
I’m creating some real-time displays in Grafana, by which I mean updates once per second.
So far, this is working well (neither browser nor server seem stressed by this).
However, every panel that I create in Grafana’s dashboard gets little circular “flash” in the top right hand corner when it updates, and with updates happening once per second, on several panels on a big screen, this is pretty distracting.
How can I turn off these update flashes, and simply have the numbers / graphs update quietly from their previous values / display?
Thanks,
Antony.
Does no-one have an idea about this?
Am I the first person to find these update flashes rather distracting?
I tried that out, definitely distracting. Maybe file a feature request to suppress the “updating” icon for intervals less than 5 seconds? Even at 5 seconds it is fairly distracting.
An url param would work as well vs trying to store the setting in a user profile.
Thanks for the confirmation. I wonder if I’m the only person using Grafana for
“really quite real-time stuff” like this.
How / where is the best way to do that please?
I’d like to see it as an additional option next to the time range and refresh
interval selections - just a tickbox saying “update indications on/off”.
profile.
I’ll let the developers consider that level of detail.
Thanks,
Antony.
You can create a new issue on GitHub - grafana/grafana: The open and composable observability and data visualization platform. Visualize metrics, logs, and traces from multiple sources like Prometheus, Loki, Elasticsearch, InfluxDB, Postgres and many more. to suggest a feature. This should be easy to implement.
