Thank you (very much) for Grafana.
I am working with data that updates over minutes and several hours and I want the UI to show this entire time period. When a new datapoint is written to influxdb, I want the UI to respond in real-time.
So far, I can have either the long time range or the second-by-second updating, but not both.
Please advise if this is possible.
E
Hello @ericmsmythe,
While it is possible to do this:
…it has obvious performance and resources drawbacks.
It is not possible to set a different refresh rate and time range for different panels on the same dashboard at this time. But you may be interested in following the conversation here: Refresh interval per panel · Issue #3514 · grafana/grafana · GitHub
Also note that the database will never update Grafana when new datapoints are written. Grafana has to send a query to obtain them, so it will never be exactly “real-time” the way you describe it, but it can get close.
Thanks @adeverteuil,
Your remark made me persevere with this use case. I had fiddled with the default in Time Range and when I noticed this and then reset it, I achieved exactly the heart beat tracking that I was looking for…
Onward …
Thanks and best wishes,
Eric
