Grafana v13.0.0 & Debian 13
- What are you trying to achieve?
I am trying to visualize my cable internet Docsis Chanels with Gauge.
- How are you trying to achieve it?
InfluxDBv2 + Flux + Gauge + Threshold
- What happened?
I actually got a simple version of this working. I can query the database, get the values and display them in the Gauge. The threshold is working too. See:
But this is where my headaches start: The thresholds have to be updated/changed based on a second value (called QAM) because the interpretation of the power level changes based on this value. So I kind of need to update the thresholds dynamicly but I have no clue how to achieve this. I tried a lot of different things, but I got no result. Can someone guide me?
