Im currently using version 9.4 -
I want to uninstall grafana -
i used the command
apt get remove grafana, sudo apt-get purge grafana, - What happened?
for all these command, i got the same reply “package grafana is not installed”
I want to uninstall grafana from my server, as it was not working well with the zabbix plugin
