Downgrade to 6.7
Hello everyone,
i developed my own react panel plugin, which worked fine until today morning my ubuntu upgraded grafana automatically to version 7.0. I do like the new version, but my plugin seem to have some issues with that upgrade.
I tried to solve that problems for some hours, but it seems to take a little longer so i decided to roll back on one computer to the version 6.7.x to keep it running until i got a solution for my plugin on my other computer.
How do i downgrade to a previous version?
Wouldn’t ubuntu automatically install the newest version with every ‘sudo apt-get update’? How do i avoid that?
Thank you for your help.
I have the exact same problem. I have created a react plugin for 6.x. I have installed grafana on the live server (latest version is 7 right now), and plugin is not working. The project would go live on monday, so I need a quick solution. The quickest would be installing Grafana 6.x on the prod server.
Sebastian, did you manege to downgrade or install 6 agian?
Anybody knows how to install older Grafana?
Thanks.
OK, next time I’ll google basic linux stuff before panicking:
sudo apt-get install grafana=6.7.4
does anyone know how i can downgrade the enterprise version to OSS as i believe i upgraded by mistake and now i have an error
Hi @danilomacedo1308,
Welcome to the :grafana: community support forums !!
This is approx 2 years old post so I am sure you are not using ver. 6.7
Therefore, can you please tell us:
1 which Grafana Enterprise version you are currently using ?
2 on which Linux or Windows distribution/version you installed it
3 how you installed it e.g. manually or via package manager etc.
4 how exactly you are trying to downgrade it ?
thanks
