Unified Alert Templating Variables not Resolved
I’m trying to setup alerts in the new unified alerting.
Grafana Version: v8.3.2
I want to build the message from template variables of the labels and can not figure out what I’m doing wrong.
The configuration:
The result:
Am I doing something wrong here?
Thank you for any help
Additional Info, everything makes even less sense to me now.
This:
Returns this:
Hello @naneosrs
Did you achieved to managed this issue ? I’m encountering the same behavior which I don’t understand !
The templated annotations are not translate to their value when text is there too.
Many thanks in advanced
kind regards,
Hi I’m sorry I missed your reply.
I never managed to fixed this, I’m afraid.
I’m using Grafana 9.3 and I still have this issue.
Has anyone solved that problem?
I have found a solution in another forum
You need use reduce function between query and condition expression and use the reduce expression as value of condition.
I believe this is the solution, resolving the variables worked for me on newer alerts I created lately and I figured the problem was resolved in some update.
But all my current alerts contain reduce expressions, so it’s likely that it was fixed for me because of that.
