Template Variables in Grafana managed alert
I am new to Grafana and I am trying Grafana managed alerts right now. I have halfway understood the setup of the alerts, but now I want to customize the text in the emails. For this I want to use Template Variables, but all the instructions I found I either didn’t understand or it just doesn’t work.
    Grafana Version 8.0.6 / Ubuntu (latest Version, only for my personal test environment)
    I would like to enrich Grafana managed alerts with content from template variables.
    I created a simple alert rule (grafana managed alert):
A - query:
node_cpu_seconds_total{mode=“system”,cpu=“0”}
B - expression:
Reduce / Max / A
C - Expression:
Math / $B > 2140
Alert details:
Summary
{{ $labels.mode }}
{{ $labels.job }}
{{ $values.A }}
{{ $values.B }}
{{ $values.C }}
{{ $values.A.value }}
{{ $labels.A.cpu }}
{{ $labels.A.mode }}
{{ $values.B.value }}
{{ $labels.B.cpu }}
{{ $labels.B.mode }}
Custom Labels
mymode = {{ $labels.mode }}
myjob = {{ $labels.job }}
mybvalue = {{ $values.B }}
mybvaluevalue = {{ $values.B.value }}
  • What happened?
    Only the two variables mymode and myjob are resolved correctly and are displayed in the alarm under labels. All other values appear only as strings.
    All variables should be resolved, especially in the summary.
    see above
    no. No errors.
    Create Grafana managed alert rule | Grafana documentation
Alarm email content:
Firing: 1 alertname
Firing Alert Prom 02
summary: {{ $labels.mode }} {{ $labels.job }} {{ $values.A }} {{ $values.B }} {{ $values.C }} {{ $values.A.value }} {{ $labels.A.cpu }} {{ $labels.A.mode }} {{ $values.B.value }} {{ $labels.B.cpu }} {{ $labels.B.mode }}
Labels:
alertname: Alert Prom 02
cpu: 0
instance: xyz.abc.de:9100
job: node_exporter
mode: system
mybvalue: {{ $values.B }}
mybvaluevalue: {{ $values.B.value }}
myjob: node_exporter
mymode: system
Can someone explain to me exactly how the syntax must be or explain to me what I am misunderstanding or doing wrong?
Are there any further instructions for Grafana managed alerts and template variables?
I have a very similar question:
    Grafana Version 8.2.0 Grafana Pro Online; New Alerting System Enabled
    I would like to enrich Grafana managed alerts with content from labels using Alert Templates
  • Alert Source: Grafana
  • Email Template:
    {{ define “rrzTestMessageAlertWithData” }}
    Labels:
    {{ range .Labels.SortedPairs }}
    {{ .Name }}: {{ .Value }}
    {{ end }}
    {{ if gt (len .Alerts.Firing) 0 }}
    {{ len .Alerts.Firing }} firing:
    {{ range .Alerts.Firing }} {{ template “alert” .}} {{ end }}
    {{ end }}
    Annotations:
    {{ if gt (len .Annotations) 0 }}
    Annotations:
    {{ range .Annotations.SortedPairs }}
    {{ end }}
    {{ end }}
    {{ if gt (len .Alerts.Resolved) 0 }}
    {{ len .Alerts.Resolved }} resolved:
    {{ range .Alerts.Resolved }} {{ template “alert” .}} {{ end }}
    {{ end }}
    {{ end }}
  • Data Source: Azure Logs/LogAnalytics
  • Example Labels
  • Q: How do I properly reference the label data: FaultingApplicationPath in the AlertTemplate?
I have the same problem.
Only {{ $labels.alertname }} and {{ $labels.datasource_uid }} are resolved.
Did you find a solution?
