I have reproduced this behavior in all the 9.x.x grafana versions.
I have a group with some alert rules in it. Some of them are firing, I edit one of the alerts of the group, doesn’t matter if it’s firing or not.
When I save the alert i was editing ALL the firing alerts are RESET to OK. It can be very misleading, because people at the helpdesk will receive a close message when the alert is still there on the data, and then they receive a second alerting email, when the alert is going to be fired again.
Is it the expected behavior?
Hi Joel, you’re right. This is because the only way to update an alert rule is updating the group it belongs. The api only let us to update all the alerts for a group, so, if one rule in a group is updated, the states of all the other rules in that group are reset.
@soniaaguilar I appreciate the answer and marked as solution, but i hope you there at Grafana realize it is an extremely dangerous behavior and not reliable at all, receiving tons of false negative closed alerts because i edited one single alert rule. It makes grafana managed alerts unsable in industrial or remote monitoring applications.
Thank you so much for your feedback @joel. Alerting team will include this problem in the list of tasks to be addressed in the future and work towards identifying the optimal solution for it.
@soniaaguilar I’m running into the same issue here. Couple questions that could help solve this for our company:
- I see that the Alerting Rule History annotates the state as “OK (Updating)”. Is it possible that the next fired alert could identify itself as being triggered after an update?
- Could you clarify about whether the “OK (Updating)” forced state is a Grafana implementation detail, a Loki one, or an AlertManager one?
In recent versions of Grafana, starting from version 11, not all changes in rules cause the state to be reset. Interval and annotations now do not cause the state reset.
We are looking into reducing it even more Alerting: Reduce set of fields that could trigger alert state change by benoittgt · Pull Request #83496 · grafana/grafana · GitHub
No, it’s not possible
This is the implementation details of Grafana Alerting. Changes in rules can affect the changes in alerts created by evaluating them. The Alertmanager will treat them as different alerts and therefore, there will be two alerts that belong to the same evaluated dimension. Read more in the issue Alerting: Reduce set of fields that could trigger alert state change by benoittgt · Pull Request #83496 · grafana/grafana · GitHub
