Hello, I recently upgraded from Grafana v9.5.0 to 11.4.0. Before this update, my alerts worked perfectly fine. If a node went down, the alerts went into a firing state and I got an email.
After this update, all of my alerting rules are in a ‘Normal’ state despite alert conditions for the rule clearly being in a firing state. This is resulting in me not being alerted if a node has a problem.
How can a rule not be in a ‘Firing’ state if one of the conditions is in a ‘Firing’ state?
For an experiment, I created a new rule that only monitors the status of one of my nodes that is currently down.
Screenshot of the alerting rule for this node:
As you can see, the rule is in a Normal state.
If I click view on the alert rule, this is what I see:
In the bottom right, you can see that the alert condition is FIRING.
Rule configs:
As you can see, the condition is CLEARLY firing but the actual rule is still in a normal state. Can someone help me figure out why the rule is not firing like it should be?
Thank you for your time.
