Unauthorized Dashboard implemented postgres with grafana
grafana.ini
  database:
    enabled: true
    type: postgres
    host: hostname:5432
    port: 5432
    user: sample
    password: db-password
    url: postgres://user:password@host:5432/db-name
    ssl_mode: disable
    reconnect: true
    binary_parameters: yes
after I Add the Db configuration in grafana–>values.yaml to integrate db into grafana i facing issue with dashboard,I am not able to access dashboard it shows unauthorize.
level=error msg="Could not find plugin definition for data source" datasource_type=PostgreSQL
logger=context t=2023-08-22T05:46:20.976861632Z level=warn msg="failed to look up session from cookie" error="pq: unnamed prepared statement does not exist"
logger=context t=2023-08-22T05:46:20.977242312Z level=error msg="Failed to get user with id" userId=2 error="pq: unnamed prepared statement does not exist"
logger=context userId=0 orgId=0 uname= t=2023-08-22T05:46:20.978842771Z level=warn msg= error="pq: unnamed prepared statement does not exist" traceID=
logger=context userId=0 orgId=0 uname= t=2023-08-22T05:46:20.979783774Z level=warn msg= error="pq: unnamed prepared statement does not exist" traceID=
logger=context userId=0 orgId=0 uname= t=2023-08-22T05:46:20.979823545Z level=info msg="Request Completed" method=GET path=/avatar/46d229b033af06a191ff2267bca9ae56 status=403 remote_addr=49.37.192.10 time_ms=7 duration=7.031342ms size=15 referer=https://sample.test.com/dashboards
logger=context t=2023-08-22T05:46:21.062320708Z level=warn msg="failed to look up session from cookie" error="pq: unnamed prepared statement does not exist"
logger=context userId=2 orgId=1 uname=admin t=2023-08-22T05:46:21.06237708Z level=error msg="Search failed" error="pq: unnamed prepared statement does not exist" remote_addr=49.37.192.10 traceID=
logger=context userId=2 orgId=1 uname=admin t=2023-08-22T05:46:21.062424361Z level=error msg="Request Completed" method=GET path=/api/search status=500 remote_addr=49.37.192.10 time_ms=4 duration=4.687973ms size=40 referer=https://sample.test.com/dashboards handler=/api/search/
logger=context userId=0 orgId=0 uname= t=2023-08-22T05:46:21.064844161Z level=warn msg=Unauthorized error="pq: unnamed prepared statement does not exist" remote_addr=49.37.192.10 traceID=
THANK YOU!!
~ the grafana team
@arunpandiyan Your browser has a cookie that becomes invalid when you switch from SQLite to Postgres. Just log-out and log in to refresh the cookie.
It started in G10 when recreating the database and has active cookies from previous sessions.
After I Clear all my Cookies and tried lot of time still show the same issue
If you guys having any idea regarding with this means please keep it posted,thanks!
Seems that there is an issue with pgbouncer.
Error says “unnamed prepared statement does not exist”
that mostly means that your bouncer is not in session mode
