Unable to view playlist, or edit and delete. Playlist not found error
This has been cross posted to github as a bug report, you can view my uploaded gif showing the issue there (image was too large to upload here):
    Docker latest image, grafana v 9.3.6
    Trying to create and play playlists
    Normal method
  • What happened?
    Getting playlist not found error when I try to play, edit, or delete a playlist
    Expect to play, edit, delete list after created.
    No errors in UI besides Playlist not found
    Chrome console gives these errors:
fetch.js:32          GET https://grafana.rsu87.org/api/playlists/1 404
(anonymous) @ fetch.js:32
e._trySubscribe @ Observable.js:38
(anonymous) @ Observable.js:32
a @ errorContext.js:19
e.subscribe @ Observable.js:23
s @ mergeInternals.js:53
(anonymous) @ mergeMap.js:14
(anonymous) @ lift.js:10
(anonymous) @ Observable.js:27
(anonymous) @ share.js:60
(anonymous) @ filter.js:6
(anonymous) @ tap.js:15
y @ mergeInternals.js:19
g @ mergeInternals.js:14
s._next @ OperatorSubscriber.js:11
t.next @ Subscriber.js:34
(anonymous) @ innerFrom.js:51
(anonymous) @ catchError.js:9
(anonymous) @ takeUntil.js:8
(anonymous) @ throwIfEmpty.js:8
(anonymous) @ backend_srv.ts:99
(anonymous) @ Subscriber.js:123
t._next @ Subscriber.js:63
(anonymous) @ Subject.js:38
t.next @ Subject.js:30
(anonymous) @ ResponseQueue.ts:30
(anonymous) @ ResponseQueue.ts:35
(anonymous) @ FetchQueueWorker.ts:54
(anonymous) @ mergeInternals.js:25
(anonymous) @ FetchQueue.ts:76
(anonymous) @ FetchQueue.ts:55
(anonymous) @ FetchQueue.ts:59
(anonymous) @ backend_srv.ts:104
(anonymous) @ map.js:6
(anonymous) @ lastValueFrom.js:7
o @ lastValueFrom.js:4
request @ backend_srv.ts:79
get @ backend_srv.ts:391
start @ PlaylistSrv.ts:82
r @ PlaylistStartPage.tsx:8
rs @ react-dom.production.min.js:157
Wi @ react-dom.production.min.js:267
Sc @ react-dom.production.min.js:250
kc @ react-dom.production.min.js:250
wc @ react-dom.production.min.js:250
hc @ react-dom.production.min.js:243
(anonymous) @ react-dom.production.min.js:123
t.unstable_runWithPriority @ scheduler.production.min.js:18
Ho @ react-dom.production.min.js:122
Vo @ react-dom.production.min.js:123
Zo @ react-dom.production.min.js:122
lc @ react-dom.production.min.js:237
enqueueSetState @ react-dom.production.min.js:133
g.setState @ react.production.min.js:12
t @ index.js:205
(anonymous) @ index.js:215
Promise.then (async)
n._loadModule @ index.js:214
n.componentWillMount @ index.js:168
va @ react-dom.production.min.js:138
Bs @ react-dom.production.min.js:181
Wi @ react-dom.production.min.js:269
ze @ react-dom.production.min.js:292
$t @ react-dom.production.min.js:73
/playlists/play/1:1 Uncaught (in promise) {status: 404, statusText: '', data: {…}, config: {…}}
I have downgraded to 8.5.16 and still the same issue.
Also, using the api gives me the same error:
curl --location --request DELETE 'https://grafana.domain.org/api/playlists/2' --header 'Authorization: Basic redacted'
result:
    "message": "Playlist not found",
    "traceID": ""
Turns out this was my fault. I had improperly mounted a docker volume. :frowning:
