v9.4.3 -
trying to provision tempo using the yaml file
in the jsonData/traceToLogs i am able to set all the fields like spanStartTimeShift, filterByTraceId
but i can’t figure out how to toggle “Use custom query” to on and set the query value -
by using the provisioning yaml file -
What happened?
all other values are shown correctly in the datasource config except “Use custom query” is turned off and query text is not set
“Use custom query” to be on and query text set as per yaml
- Can you copy/paste the configuration(s) that you are having problems with?
datasources:
- name: Tempo
type: tempo
uid: tempo
access: proxy
orgId: 1
url: http://tempo:3200
basicAuth: false
isDefault: false
editable: true
jsonData:
httpMethod: GET
tracesToLogs:
datasourceUid: loki
spanStartTimeShift: '-1h'
spanEndTimeShift: '+1h'
filterByTraceID: false
filterBySpanID: false
customQuery: true
query: '{{exporter="OTLP"} | json | trace_id="${__span.traceId}" | span_id="${__span.spanId}"}'
serviceMap:
datasourceUid: prometheus
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
no
- Did you follow any online instructions? If so, what is the URL?
tried to find it in the grafana documentation but nothing came up
