I’m provisioning my Tempo Data Source in Grafana using YAML. Is there a Way to select the Loki Data Source for Tempo?
Currently I have something like this:
apiVersion: 1
datasources:
- name: Tempo
type: tempo
access: proxy
url: "http://monitoring-tempo:3100"
Hi, this is our internal configuration at Grafana Labs:
datasources:
- name: Tempo
type: tempo
jsonData:
tracesToLogs:
datasourceUid: <name of your Loki datasource>
tags:
- cluster
- namespace
- pod
# More configuration here...
The cluster, namespace and pod labels will be copied from the Tempo span and used in the query on Loki. In your specific application, you might want to use other labels.
