We’ve configured grafana, loki, tempo and promtail as docker containers in a compose file,
docker-compose.yaml
version: '3.9'
x-logging:
&default-logging
driver: "json-file"
options:
max-size: "1m"
max-file: "1"
tag: "{{.Name}}"
services:
grafana:
image: grafana/grafana:11.0.0-ubuntu #grafana/grafana:10.4.2
container_name: grafana
ports:
- 3000:3000
environment:
- GF_AUTH_ANONYMOUS_ENABLED=true
- GF_AUTH_ANONYMOUS_ORG_ROLE=Admin
- GF_USERS_DEFAULT_THEME=light
volumes:
- ./configs/grafana/datasources.yaml:/etc/grafana/provisioning/datasources/datasources.yaml:ro
depends_on:
- tempo
networks:
- traces
logging: *default-logging
tempo:
image: grafana/tempo:latest #grafana/tempo:2.3.1
container_name: tempo
ports:
- 3200:3200 # tempo http
- 9095:9095 # tempo grpc
- 14268:14268 # jaeger ingest
- 4318:4318 # otlp http
- 4317:4317 # otlp grpc
volumes:
- ./configs/tempo/tempo-local.yaml:/etc/tempo-local.yaml
command: ["-config.file=/etc/tempo-local.yaml"]
networks:
- traces
promtail:
image: grafana/promtail:main #grafana/promtail:2.9.7
container_name: promtail
volumes:
- ./configs/promtail/promtail.yaml:/etc/promtail/docker-config.yaml
- /var/lib/docker/containers:/var/lib/docker/containers:ro
- /var/run/docker.sock:/var/run/docker.sock
command: -config.file=/etc/promtail/docker-config.yaml
depends_on:
- loki
networks:
- traces
loki:
image: grafana/loki:main #grafana/loki:2.9.7
container_name: loki
ports:
- 3100:3100
command: -config.file=/etc/loki/local-config.yaml
networks:
- traces
networks:
traces:
driver: bridge
promtail.yaml
server:
http_listen_port: 9080
grpc_listen_port: 0
positions:
filename: /tmp/positions.yaml
clients:
- URL: <loki endpoint>
scrape_configs:
- job_name: flog_scrape
docker_sd_configs:
- host: unix:///var/run/docker.sock
refresh_interval: 5s
filters:
- name: label
values: ["logging=promtail"]
relabel_configs:
- source_labels: ['__meta_docker_container_name']
regex: '/(.*)'
target_label: 'container'
- source_labels: ['__meta_docker_container_log_stream']
target_label: 'logstream'
- source_labels: ['__meta_docker_container_label_logging_jobname']
target_label: 'job'
pipeline_stages:
- cri: {}
- multiline:
#firstline: ^\d{4}-\d{2}-\d{2} \d{1,2}:\d{2}:\d{2},\d{3}
firstline: '(?P<time>\\d{2}:\\d{2}:\\d{2}\\.\\d{3}) \\[.*?\\] \\[traceId=(\\w+), spanId=(\\w+)\\] \\S+ \\S+:\\d+ \\| .*'
max_wait_time: 3s
# https://grafana.com/docs/loki/latest/clients/promtail/stages/json/
- json:
expressions:
#message: message
level: level
#output: 'message'
tempo-local.yaml
server:
http_listen_port: 3200
distributor:
receivers:
jaeger:
protocols:
grpc:
thrift_compact:
thrift_binary:
thrift_http:
otlp:
protocols:
http:
endpoint: 0.0.0.0:55681
grpc:
endpoint: 0.0.0.0:4317
ingester:
trace_idle_period: 10s
max_block_bytes: 1_000_000
max_block_duration: 5m
compactor:
compaction:
block_retention: 48h
compacted_block_retention: 1h
storage:
trace:
backend: local
local:
path: /var/tempo/traces
block:
bloom_filter_false_positive: 0.05
v2_index_downsample_bytes: 1000
v2_encoding: zstd
metrics_generator:
registry:
external_labels:
source: tempo
cluster: docker-compose
storage:
path: /tmp/tempo/generator/wal
remote_write:
- url: http://prometheus:9090/api/v1/write
send_exemplars: true
overrides:
defaults:
metrics_generator:
processors: [service-graphs, span-metrics] # enables metrics generator
#overrides:
# per_tenant_override_config: /conf/overrides.yaml
Here’s also the app configuration in the logback.xml file
<appender name="LOKI" class="com.github.loki4j.logback.Loki4jAppender">
<http>
<url>http://localhost:3100/loki/api/v1/push</url>
</http>
<format>
<label>
<pattern>app=${appName},host=${HOSTNAME},level=%level</pattern>
</label>
<message>
<pattern>%d{HH:mm:ss.SSS} [%thread] [traceId=%X{traceId}, spanId=%X{spanId}] %-5level %file:%line | %msg%n</pattern>
</message>
<sortByTime>true</sortByTime>
</format>
</appender>
<root level="INFO">
<appender-ref ref="LOKI"/>
<appender-ref ref="STDOUT" />
</root>
The application logs get streamed to loki, however, the logs with traceID and span ID are not visible in the tempo datasource
