Hi Grafana community,
I wanted to load my existing application logs to Loki and wanted to follow traces there. How can I accomplish this without needing application instrumentation such as OpenTelemetry?
Here is my current set up
Configured Grafana and Loki without problems.
Successfully sent logs from ElasticSearch to Loki using Logtash.
Logs are available from Grafana.
Derived field has been added to Loki with internal link to Tempo correctly
But when I search a traceid in Tempo, I get an error such as as
failed to get trace with id: 2f506bd0428518c549c87421 Status: 404 Not Found Body: trace not found
TraceQL from Tempo doesn’t return anything on { }
Using the Loki Search feature inside Tempo returns null for Trace ID
No error exists in the application logs
tempo.yaml
stream_over_http_enabled: true
server:
http_listen_port: 3200
log_level: info
query_frontend:
search:
duration_slo: 5s
throughput_bytes_slo: 1.073741824e+09
trace_by_id:
duration_slo: 5s
distributor:
# Optional.
# Enable to metric every received span to help debug ingestion
# This is not recommended for production environments
log_received_spans:
enabled: true
metric_received_spans:
enabled: true
receivers: # this configuration will listen on all ports and protocols that tempo is capable of.
jaeger: # the receives all come from the OpenTelemetry collector. more configuration information can
protocols: # be found there: https://github.com/open-telemetry/opentelemetry-collector/tree/main/receiver
thrift_http: #
grpc: # for a production deployment you should only enable the receivers you need!
thrift_binary:
thrift_compact:
zipkin:
otlp:
protocols:
http:
grpc:
opencensus:
ingester:
max_block_duration: 5m # cut the headblock when this much time passes. this is being set for demo purposes and should probably be left alone normally
compactor:
compaction:
block_retention: 24h # overall Tempo trace retention. set for demo purposes
metrics_generator:
registry:
external_labels:
source: tempo
cluster: docker-compose
storage:
path: /tmp/tempo/generator/wal
remote_write:
- url: http://prometheus:9090/api/v1/write
send_exemplars: true
storage:
trace:
backend: local # backend configuration to use
wal:
path: /tmp/tempo/wal # where to store the the wal locally
local:
path: /tmp/tempo/blocks
overrides:
defaults:
metrics_generator:
processors: [service-graphs, span-metrics] # enables metrics generator
loki-config.yaml
auth_enabled: false
server:
http_listen_port: 3100
grpc_listen_port: 9096
common:
path_prefix: /tmp/loki
storage:
filesystem:
chunks_directory: /tmp/loki/chunks
rules_directory: /tmp/loki/rules
replication_factor: 1
ring:
instance_addr: 127.0.0.1
kvstore:
store: inmemory
schema_config:
configs:
store: boltdb-shipper
object_store: filesystem
schema: v11
index:
prefix: index_
period: 24h
ruler:
alertmanager_url: http://localhost:9093
docker-compose.yml
version: "3"
services:
grafana:
image: grafana/grafana:latest
container_name: grafana
volumes:
- /root/dockerfiles/cloki/grafana:/var/lib/grafana
environment:
- GF_SECURITY_ADMIN_USER=${ADMIN_USER:-admin}
- GF_SECURITY_ADMIN_PASSWORD=${ADMIN_PASSWORD:-admin}
restart: unless-stopped
user: "0" # IMPORTANT, change this id (unique), get by running 'id -u',
ports:
- "3001:3000" # change(left) if used by other services/containers
networks:
- elk_to_loki
qryn:
image: qxip/qryn:latest
container_name: loki
volumes:
- /root/dockerfiles/cloki/loki:/etc/loki
expose:
- 3100
ports:
- "3100:3100"
environment:
- CLICKHOUSE_SERVER=clickhouse-seed
- DEBUG=true
depends_on:
- clickhouse-seed
networks:
- elk_to_loki
promtail:
image: grafana/promtail:latest
volumes:
- /var/log:/var/log
- /root/dockerfiles/cloki/promtail:/etc/promtail
- /var/run/docker.sock:/var/run/docker.sock # neccessary for docker logging (do not forget the plugin!!)
command: -config.file=/etc/promtail/promtail-config.yml
networks:
- elk_to_loki
# ports:
# - "1514:1514" # only needed for syslogs
clickhouse-seed:
image: yandex/clickhouse-server
container_name: clickhouse-seed
ports:
- 8123:8123
networks:
- elk_to_loki
clickhouse-client:
container_name: clickhouse-client
image: yandex/clickhouse-client
entrypoint:
- /bin/sleep
command:
- infinity
networks:
- elk_to_loki
# logstash:
# image: grafana/logstash-output-loki # for using loki as output # docker.elastic.co/logstash/logstash:
# container_name: logstash
# volumes:
# - /root/dockerfiles/cloki/logstash/logstash.conf:/etc/logstash/conf.d/logstash.conf
# - /root/dockerfiles/cloki/logstash/certs:/etc/logstash/certs/
# - /root/dockerfiles/cloki/logstash/logstash.yml:/usr/share/logstash/config/logstash.yml
# networks:
# - elk_to_loki
# command: >
# bash -c "bundle update
# && logstash -f /etc/logstash/conf.d/logstash.conf"
# # above for using opensearch as input
tempo:
image: grafana/tempo:latest
command: [ "-config.file=/etc/tempo.yaml" ]
volumes:
- /root/dockerfiles/cloki/tempo/tempo.yaml:/etc/tempo.yaml
ports:
- "3200:3200" # tempo
- "4317:4317" # otlp grpc
- "4318:4318" # otlp http
networks:
- elk_to_loki
# otel-collector:
# image: otel/opentelemetry-collector
# command: ["--config=/etc/otel-collector-config.yaml"]
# volumes:
# - /root/dockerfiles/cloki/otelc/otel-collector-config.yaml:/etc/otel-collector-config.yaml
# ports:
# - "4317:4317" # OTLP gRPC receiver
networks:
elk_to_loki:
external: true```
