I am trying to setup the tempo trace to loki logs in connections.
Can any one please help me with the query for the linking the logs to loki ?
Here is the sample trace json
"batches": [
"resource": {
"attributes": [
"key": "telemetry.sdk.language",
"value": {
"stringValue": "nodejs"
"key": "telemetry.sdk.name",
"value": {
"stringValue": "opentelemetry"
"key": "telemetry.sdk.version",
"value": {
"stringValue": "1.15.2"
"key": "container.id",
"value": {
"stringValue": "eb3b3c97119b7ff00c50ee3473aac0fc5fd0692c85c14004d9e7eded64.scope"
"key": "service.namespace",
"value": {
"stringValue": "opentelemetry-poc"
"key": "host.name",
"value": {
"stringValue": "opentelemetry-demo-frontend-787b4d49b7-xtcw2"
"key": "host.arch",
"value": {
"stringValue": "amd64"
"key": "os.type",
"value": {
"stringValue": "linux"
"key": "os.version",
"value": {
"stringValue": "4.18.0-372.71.1.el8_6.x86_64"
"key": "process.pid",
"value": {
"intValue": 17
"key": "process.executable.name",
"value": {
"stringValue": "node"
"key": "process.executable.path",
"value": {
"stringValue": "/usr/local/bin/node"
"key": "process.command_args",
"value": {
"stringValue": "[\"/usr/local/bin/node\",\"--require\",\"./Instrumentation.js\",\"/app/server.js\"]"
"key": "process.runtime.version",
"value": {
"stringValue": "18.18.2"
"key": "process.runtime.name",
"value": {
"key": "process.runtime.description",
"value": {
"stringValue": "Node.js"
"key": "process.command",
"value": {
"stringValue": "/app/server.js"
"key": "process.owner",
"value": {
"stringValue": "nextjs"
"key": "k8s.pod.ip",
"value": {
"stringValue": "10.128.8.90"
"key": "k8s.node.name",
"value": {
"stringValue": "00-50-56-be-8e-d8"
"key": "k8s.pod.start_time",
"value": {
"stringValue": "2023-12-18 14:33:34 +0000 UTC"
"key": "k8s.pod.uid",
"value": {
"stringValue": "e3919530-a477-4a34-95ed-48d69da35397"
"key": "k8s.deployment.name",
"value": {
"stringValue": "opentelemetry-demo-frontend"
"key": "service.instance.id",
"value": {
"key": "service.name",
"value": {
"stringValue": "frontend"
"key": "k8s.namespace.name",
"value": {
"key": "k8s.pod.name",
"value": {
"droppedAttributesCount": 0
"instrumentationLibrarySpans": [
"spans": [
"traceId": "43e54a049bc8b09ca45f06f8560e8ad3",
"spanId": "836452e26293d56f",
"parentSpanId": "d7c696f2965fa23f",
"traceState": "",
"name": "grpc.oteldemo.AdService/GetAds",
"kind": "SPAN_KIND_CLIENT",
"startTimeUnixNano": 1702910384753000000,
"endTimeUnixNano": 1702910384756656000,
"attributes": [
"key": "rpc.system",
"value": {
"stringValue": "grpc"
"key": "rpc.method",
"value": {
"stringValue": "GetAds"
"key": "rpc.service",
"value": {
"stringValue": "oteldemo.AdService"
"key": "net.peer.name",
"value": {
"stringValue": "opentelemetry-demo-adservice"
"key": "net.peer.port",
"value": {
"intValue": 8080
"key": "rpc.grpc.status_code",
"value": {
"intValue": 0
"droppedAttributesCount": 0,
"droppedEventsCount": 0,
"droppedLinksCount": 0,
"status": {
"code": 0,
"message": ""
"instrumentationLibrary": {
"name": "@opentelemetry/instrumentation-grpc",
"version": "0.41.2"
"resource": {
"attributes": [
"value": {
"value": {
"value": {
"value": {
"value": {
"key": "host.name",
"value": {
"key": "host.arch",
"value": {
"key": "os.type",
"value": {
"value": {
"value": {
"intValue": 17
"value": {
"value": {
"value": {
"value": {
"value": {
"value": {
"value": {
"value": {
"value": {
"value": {
"value": {
"value": {
"value": {
"value": {
"value": {
"value": {
"value": {
"spans": [
"spanId": "d7c696f2965fa23f",
"parentSpanId": "0000000000000000",
"traceState": "",
"name": "HTTP GET",
"kind": "SPAN_KIND_SERVER",
"endTimeUnixNano": 1702910384756981800,
"attributes": [
"key": "app.synthetic_request",
"value": {
"boolValue": true
"key": "http.target",
"value": {
"stringValue": "/api/data"
"key": "http.user_agent",
"value": {
"stringValue": "python-requests/2.31.0"
"key": "http.flavor",
"value": {
"stringValue": "1.1"
"key": "http.method",
"value": {
"stringValue": "GET"
"key": "http.url",
"value": {
"stringValue": "opentelemetry-demo-frontendproxy:8080/api/data"
"key": "http.status_code",
"value": {
"intValue": 200
"status": {
"code": 0,
"message": ""
"links": [
"traceId": "d39d0e3fe09113da71fe2e16a0b8d597",
"spanId": "c3e4ef1b200c3679",
"attributes": [],
"name": "frontend",
"version": ""
"resource": {
"attributes": [
"value": {
"stringValue": "7de2f15ffbf92a1e17f5f6b9e0f1aa3179b143f4b3cddc0ca932cdfd26fa5f14"
"key": "host.arch",
"value": {
"key": "host.name",
"value": {
"stringValue": "opentelemetry-demo-adservice-54db87b68f-hbhk4"
"key": "os.description",
"value": {
"stringValue": "Linux 4.18.0-372.71.1.el8_6.x86_64"
"key": "os.type",
"value": {
"key": "process.command_line",
"value": {
"stringValue": "/opt/java/openjdk/bin/java -javaagent:/usr/src/app/opentelemetry-javaagent.jar oteldemo.AdService"
"value": {
"stringValue": "/opt/java/openjdk/bin/java"
"value": {
"intValue": 1
"value": {
"stringValue": "Eclipse Adoptium OpenJDK 64-Bit Server VM 17.0.8.1+1"
"value": {
"stringValue": "OpenJDK Runtime Environment"
"value": {
"stringValue": "17.0.8.1+1"
"value": {
"key": "telemetry.auto.version",
"value": {
"stringValue": "1.28.0"
"value": {
"stringValue": "java"
"value": {
"value": {
"value": {
"stringValue": "10.130.2.185"
"value": {
"stringValue": "00-50-56-be-9f-af"
"value": {
"stringValue": "2023-12-18 14:27:57 +0000 UTC"
"value": {
"stringValue": "c1cbba51-e5fb-42b3-9d8c-bf523d4c989d"
"value": {
"value": {
"value": {
"stringValue": "adservice"
"value": {
"value": {
"spans": [
"spanId": "18d4fa0ec560e730",
"parentSpanId": "836452e26293d56f",
"traceState": "",
"name": "oteldemo.AdService/GetAds",
"startTimeUnixNano": 1702910384755497000,
"endTimeUnixNano": 1702910384756744700,
"attributes": [
"value": {
"intValue": 0
"key": "net.sock.peer.port",
"value": {
"intValue": 59466
"value": {
"key": "thread.id",
"value": {
"intValue": 36
"key": "app.ads.ad_response_type",
"value": {
"stringValue": "RANDOM"
"key": "app.ads.count",
"value": {
"intValue": 2
"key": "net.host.port",
"value": {
"intValue": 8080
"key": "net.host.name",
"value": {
"value": {
"key": "net.sock.peer.addr",
"value": {
"key": "app.ads.contextKeys.count",
"value": {
"intValue": 0
"key": "app.ads.contextKeys",
"value": {
"stringValue": "[]"
"key": "app.ads.ad_request_type",
"value": {
"stringValue": "NOT_TARGETED"
"value": {
"key": "thread.name",
"value": {
"stringValue": "grpc-default-executor-0"
"status": {
"code": 0,
"message": ""
"events": [
"timeUnixNano": 1702910384755771100,
"attributes": [
"key": "message",
"value": {
"stringValue": {
"Type": "STRING",
"Value": "message"
"key": "message.id",
"value": {
"intValue": 1
"key": "message.type",
"value": {
"stringValue": "RECEIVED"
"name": ""
"timeUnixNano": 1702910384756583400,
"attributes": [
"key": "message",
"value": {
"stringValue": {
"Type": "STRING",
"Value": "message"
"value": {
"intValue": 2
"value": {
"stringValue": "SENT"
"name": ""
"spanId": "ea0f1a48b40587ba",
"parentSpanId": "18d4fa0ec560e730",
"traceState": "",
"name": "getRandomAds",
"kind": "SPAN_KIND_INTERNAL",
"startTimeUnixNano": 1702910384756238600,
"endTimeUnixNano": 1702910384756318500,
"attributes": [
"key": "thread.id",
"value": {
"intValue": 36
"value": {
"intValue": 2
"value": {
"status": {
"code": 0,
"message": ""
"name": "io.opentelemetry.grpc-1.6",
"version": "1.28.0-alpha"
