Tempo: link logs with traceid
Hey there,
can someone explain me how I get this Button:
I have the traceid in my scraped logs. This traces are also in tempo but somehow Grafana won’t detect the connection and doesn’t display this button.
Thanks Tom
Hi :wave: You can achieve this by configuring a derived field in the Loki datasource.
Check out the Grafana docs: Loki | Grafana Labs
Thanks again :slight_smile:
Can you tell me why it looks like a placeholder and not a value when I deploy it via grafana helmchart?
Clicking the tempo button then results in tempo opening without a query.
If I write the same value manually in this field it works properly:
datasources = [
              name      = "Loki"
              type      = "loki"
              uid       = "loki"
              url       = "http://loki-distributed-gateway.loki.svc.cluster.local"
              isDefault = true
              jsonData = {
                 derivedFields =[{
                   datasourceUid = "tempo"
                   matcherRegex = "tid=(\\w+)"
                   name = "TraceID"
                   url = "$${__value.raw}"
I’m not entirely familiar with the Grafana helm chart and how datasources are loaded.
Your config seems to match the example here, the only difference I see is that the docs use single quotes:
'$${__value.raw}'
while you use double:
"$${__value.raw}"
Not sure if this matters, but might be worth trying.
Thanks for your reply :slight_smile:
Single quotes don’t work in terraform :confused:
But I see in the configmap that the value ${__value.raw} is set correctly.
Weird… we don’t use the helm charts internally (AFAIK), but I can share part of the configmaps we use. Your configmap should look similar.
So this is a Loki datasource in a configmap from our internal infrastructure. I’ve kept all fields for context, but only the part under derivedFields should matter.
    apiVersion: 1
    datasources:
      - access: proxy
        editable: false
        isDefault: false
        jsonData:
            derivedFields:
              - datasourceUid: tempo
                matcherRegex: (?:traceID|trace_id|tid)=(\w+)
                url: $${__value.raw}
            httpMethod: GET
        type: loki
        url: http://<loki>
        version: 1
Ok, thanks a lot!!! Apparently, we had to escape the $ signs once more because terraform escape a $ sign with a $ sign :smiley:
Your configuration file gave us the right tip.
Oh right, because Terraform interprets "${...}" as string interpolation :sweat_smile: Glad you figured it out :smiley:
