Unable to set "all values" filter to filter traces
I have a dashboards with grafana/tempo with 2 variables defined: service name and operation (span name). For both, I need an “ALL values” option.
For simplicity, let’s assume I have 2 service names: products-api, availability-api. I want my dashboard table widget + traces widget to rely on these variables (obviously). And here comes the problem.
When I choose a single service (not all), e.g. products, all works fine:
{resource.service.name="products-api"}- this returns results as expected :ok_hand:
But when I click “ALL” then I get following query: {resource.service.name="products-api\\|availability-api"} which never returns what it should.
I’ve tried regexes, manually defining values (in the query), I tried “custom ALL value“ in variable definition and I failed miserably with each of them and I’ve run out of ideas. And I hope this should be doable, as it seems such an important feature to have…
Any help would be appreciated, thank you.
Generally, define custom All value, as wild char regexp (blind guess .*) and then write regexp query, which will use it, e.g.
{resource.service.name=~"$servicenamevariable"}
This is not copy/paste example, so test it/improve it (syntax issues, regex issue, tempo issues, variable formatting, …) for your desired state.
I have already tried that - and the problem I encountered is that .* gets escaped by grafana and it doesn’t work as expected :frowning:
This is what gets executed - after variable gets applied (more or less, maybe not 100% accurate, but fails to work as expected)
{resource.service.name=~"\\.*\\"}
A follow up USECASE. Even if showing traces for all services (service names) might be questionable, nevermind - I have a need to configure a dashboard variable “operation”, which filters by span name, example values are: “GET / something”, “specific instrumentaion operation X” etc. And in this case I really need to show ALL traces, even within one service.
All grafana resources I’ve seen seem to use “expore” tab for traces and haven’t found a trace-specific dashboard. Could it be that hardly anyone configures trace-specific grafana dashboards (and so a rather obvious scenario is unsupported, as people are happy with “explore” tab)?
Use advance variable and use raw format so there is no special magic/escapes:
{resource.service.name=~"${servicenamevariable:raw}"}
