Hi
I am building a smart home. Heart of the system is a server running unraid with dockerized versions of home assistant, mosquitto broker etc.
I have designed embedded devices based on ESP32 for controlling switches, bulbs etc.
For collecting logs from the devices I deciced to try Grafana/Loki. My devices can push logg messages to Loki.
My development computer is based on Windows 10 and WSL2 running docker.
I’ve tried different methods for installing Grafana/Loki on WSL2/docker.
Both of them give me the same error when trying to add Loki as data source in Grafana.
Loki: Bad Gateway. 502. Bad Gateway
Googling I found out that this has been a known error but as far I understand it should have been corrected now. The suggested fix is as far I can see implemented.
Instructions that I have followed:
Simple scalable cluster | Grafana Labs.
and
I would very much apritiate some help here…
